November 1, 2018 at 10:55 pm
salocin155
SubscriberHi, first of all sorry for my bad english its not my mother language, would like to see if someone can check if my boundary conditions have been right apllied at my model, its a bar with a hole this hole is fixed with a bolt on a lever arm in this simulation i want to test my bar to see if it wont break with the load.
will atach my simulation and the lever arm image to make it more clear.
November 1, 2018 at 11:56 pm
Sandeep Medikonda
Ansys EmployeeWhat is the stress-strain response of the material? That observed stress response looks quite small and your model should hold.
Refer to this discussion.
Sandeep
Best Practices on the Student Community -
November 2, 2018 at 12:04 am
salocin155
SubscriberMaterial is steel, would compression only be the right boundarie for this situation ?
November 2, 2018 at 12:32 am
peteroznewman
SubscriberSalocin,
Compression only is a good boundary condition for the hole in the rod with the tension created by gravity.
In addition to the references Sandeep provided, I would add one additional link, and that is to a Mesh Refinement Study. The mesh you show is coarse and as you use smaller elements around the region of maximum stress, the value of stress will go up slightly. However, the stress you show is very low compared with the strength of steel, so you might not bother in this case.
For a rod with a hole in it, you could replace the block and gravity with a force on the end of the rod. That will solve more quickly because you won't have all the elements in the block that are just there to produce weight.
Peter -
November 2, 2018 at 12:45 am
salocin155
SubscriberTy vm Peter will give a look to the references and replace the block with the force.
- The topic ‘Help with static simulation’ is closed to new replies.
5639
1885
1403
1303
