November 22, 2024 at 6:39 pm
sanjaynaveen22
SubscriberHey guys, I'm a fina year mechanical engineering student and only I've been ANSYS for a while, I've got my projecy deadline so close due to unfortunate circumstances. I wanna know how to simulate a sand battery, where i want to simulate how the heat dissipates into the sand when its heated by a coil. and then the rate at which is expels out heat when it is idle.
I tried creating a model but stuck at the same, there's gonna be a stainless steel container which would be filled up with powdered quartz sand, then a coil inserted (probably water heater) and then mineral wool wrapped around the container to act as the insulator.
November 26, 2024 at 9:51 am
Forum ModeratorHave a look at the Thermal modelling options in Learning. From the above, the only fluid part would be the water heater, so maybe also review the topic in Structural (Mechanical) too?Â
5824
