December 17, 2021 at 7:54 am
December 17, 2021 at 8:22 am
December 17, 2021 at 9:47 am
Devendra Badgujar
Forum ModeratorHi Timo van Aanholt
No, it is not possible to create sheet-metal tabs from the center of a edge, instead of from the side of a edge.Â
Possible way to do this may be to split the sheet there and use the Tab tool.
Also if you want to create a single tab between two points at any location on the edge you can use Select Points Option in Tab tool.
Regards.
December 17, 2021 at 9:57 am
timo
SubscriberHi Devendra BadgujarÂ
Thank you for your quick answer!
unfortunately i was aware of both solutions.
is there a way to submit this as a feature request?
December 17, 2021 at 10:04 am
Devendra Badgujar
We thank you for sharing your feedback. We will share your idea/input with the product development team.
- The topic ‘Help with Sheet metal tabs’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Data Center Simulation
- DXF file loaded incorrectly
- Inventor 2025 files
- [SpaceClaim] STEP file size using Converter.exe
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- Spaceclaim 2024 error FNE activation failed
- Ansys Discovery Crashing vGPU (Reproducible)
- How to do the snap fit insertion FEA?
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
930
599
591
569
