Preprocessing
Preprocessing
help with mesh generation
    • Daidalos
      Hi all, I need some help with my mesh. Attached below is my current mesh.
      I would like to simulate a nozzle exhaust flow. As such I want the left edge of the plane (axis) to be refined. However, as seen in the second picture, the mesh does not transition as smooth as I would hope for towards the right. Currently I am using edge sizing at  the bottom edge to get a better transition but the transition only occurs at the bottom edge. Is there a method I can use to get better mesh? I previously ran a k-epsilon standard PISO scheme for this VOF which I believe should be quite suitable for my problem but the k and epsilon residual is very unstable and I assume its cause of my mesh.
      Thanks in advance for any advice.
      Overall mesh
      mesh closeup at nozzle inlet.
    • Karthik Remella
      Administrator
      Please decompose the domain so that you are able to create a structured mesh. This is an easy geometry to generate a structured mesh. And it might be very useful in your analysis. Here is a video series (4 parts) that discusses domain decomposition as well as generating structured meshes. Also, please try using 'Face Meshing' option is Ansys Meshing.
      https://youtu.be/P19GOTQWmc0
      https://youtu.be/XvczcKVfGnI
      https://youtu.be/aY7DziKp_ng
      https://youtu.be/Q9vtmTlCK9c
      I hope this helps.
      Thank you.
      Karthik
  • The topic ‘help with mesh generation’ is closed to new replies.
