Help while opening file: sopeninputfile: unable to open file for input
    • edeng80
      Hi community.
      I am starting with Ansys Fluent learning.
      I am facing problem while open first file in fluent.
      Error displayed:
      I have tried locating file in several places, as well as opening it from File-> Read, from the fluent window.
      Thanks in advance
    • supreetha.j
      Could you please check if there is enough space, memory or permission to access the file you are trying to load?
      Thank you.
    • edeng80
      Thanks for your answer Supreetha J
      I check about space, and memory, and it was ok. I finally solved by unnistalling and installing Fluent again.
      Thanks for your support.
  • The topic ‘Help while opening file: sopeninputfile: unable to open file for input’ is closed to new replies.
