January 6, 2021 at 5:34 pm
sentenza
SubscriberHi everybody, I'm a newbie and I need your help how visualizing the flow speed in the 2 outlets. I'm using discovery live and I can't have the two speed graphs for the different outlets: tt gives me the same speed for both. What can I do to differentiate the speed calculation? thanks a lot
January 7, 2021 at 3:14 pmNaresh Patre
Ansys EmployeeHello sentenza,nThe fluid volume is hidden by default so you may end up selecting the faces of the solid pipe. Make sure that you have first displayed the fluid volume and then selected its outlet faces for calculating. nJanuary 7, 2021 at 7:14 pmsentenza
SubscriberI de-selected solid body to display only fluid volume and selected the two outlet faces, but i have always the same result. Maybe i have to do some operations on fluid volume? (just like separate in different volumes? ....just a thought). I'm sorry if this is a very basilar question. nJanuary 7, 2021 at 7:46 pmsentenza
SubscribernJanuary 11, 2021 at 1:25 pmNaresh Patre
Ansys EmployeeHello sentenzanIf you hover the mouse cursor over the chart in the Calculations folder located in the physics tree, it should highlight the face selected as input. is it showing the outlet face in your case? Can you share snapshot where the outlet face is getting highlighted for both the calculators?nJanuary 11, 2021 at 9:19 pmsentenza
Subscriberthank you I solved, It was my mistake in selecting faces.....other questions:n1) i want to give mass flow at inlet and pressure at the outlet. If I want to give 2 bar as outlet pressure, is this pressure intended as gauge pressure?n2) if I want to add a compressibile gas like steam in the library, should I consider absolute pressure to calculate density?nViewing 5 reply threads- The topic ‘help visualizing velocity in different outlets’ is closed to new replies.
3597
1283
1117
1068
983
