October 21, 2023 at 9:27 am
October 21, 2023 at 9:39 am
October 21, 2023 at 10:20 am
peteroznewman
SubscriberI suggest you extrude those lines as zero thickness surfaces instead of solid bodies. When you have the surfaces you need, use Shared Topology to make the mesh connect across separate surface bodies. In Mechanical, you can assign the thickness to the surfaces that the shell elements will use.
- The topic ‘HELP: Self intersecting or invalid profiles were ignored’ is closed to new replies.
1890
1419
