February 6, 2024 at 5:59 pm
jmcclos8
SubscriberHi,Â
I am attemping to run a thermo-structrural anysis in Ansys using a combination of shell and solid bodies. Whenever I add the shell bodies to the simulation, I recieve the following fatal error:Â
*** ERROR ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â Â 51.047Â Â TIME= 12:48:25
 Element 575961 references undefined KXX of material 47.               ÂDoes anyone know why this is occuring and how to fix it? -
February 8, 2024 at 4:43 am
Aniket
Forum Moderator -
February 8, 2024 at 3:10 pm
jmcclos8
SubscriberHi Aniket,
Thank you for your response. I have a attached an image of my material properties that I am using for my shell elements. I think this issue is arrising because shell elements have 6 Dof whereas solid elements have 3 Dof. However, I am unsure how to fix my thermal material properties so this issue doesn't persist. Any advice advice you could offfer would be much apperciated.Â
Best,Â
Jacob
- The topic ‘Help Resolving “An Unknown Error Occurred during Solution … “’ is closed to new replies.
4843
1587
1386
1242
