TAGGED: #fluent-#ansys, #fluent-#cfd-#ansys, fluent, rocky-dem
January 11, 2024 at 12:11 pm
gy wang
SubscriberHelp post! I'm having problems with rocky. I do fluent and rocky coupling calculations, after the particle enters the inlet, it passes through the entire watershed, but it stops at outlet, it can't pass through, and I wonder how to solve it. If you have encountered similar problems and solved it, hope to get your help, thank you very much!
January 11, 2024 at 1:32 pm
Forum ModeratorCheck what geometry is present in Rocky. Unless you're using SPH or have set something special you only really need the surfaces that represent walls or other boundaries that particles don't pass through. Tutorials should be available in Learning fairly soon, but I don't yet have any additional details.
January 11, 2024 at 3:20 pm
gy wang
SubscriberI do have some problems, I'm doing a coupling calculation of rocky and fluent, and import fluent data into rocky through workbench. But Rocky recognizes Fluent's watershed geometry as a wall, and once the particles enter the watershed, they can't get out. I'm distressed.
January 11, 2024 at 3:59 pm
Forum ModeratorOK, I do suggest not using Workbench. Open Rocky from the Start menu. In Rocky's geometry you should see Fluent's boundaries, delete all interior surfaces and (in this case) the outlet. We are adding a Rocky course to the AIS (Learning) system, so it will be easier to learn shortly.
- The topic ‘Help post! FLUENT—ROCKY coupling calculation errors!’ is closed to new replies.
5639
1885
1403
1303
