August 29, 2024 at 3:37 pm
csolanov
SubscriberHello,Â
I'm running a udf to calculate heat flux values along 4 boundary faces in a 2d solid domain. this is the udf
#include "udf.h"#include "sg.h"ÂDEFINE_EXECUTE_AT_END(Direct){  int i, ID, zone[4] = { 4, 5, 6, 7};  double ds, A_by_es, flux, DTX, DTY, Area;  double H_flux[3], A[ND_ND], es[ND_ND], dr0[ND_ND];  face_t f;  cell_t c0;  Thread* t0, * t;  Domain* d = Get_Domain(1);  FILE* fp;  fp = fopen("Data.txt", "a"); // Use append mode  if (fp == NULL) {    Message("Error opening file!\n");    return;  }  for (i = 0; i < 4; i++) { // Loop over all zones    flux = 0.0;    DTX = 0.0;    DTY = 0.0;    Area = 0.0;    ID = zone[i];    t = Lookup_Thread(d, ID);    begin_f_loop(f, t)    {      BOUNDARY_FACE_GEOMETRY(f, t, A, ds, es, A_by_es, dr0);      Area += NV_MAG(A);      c0 = F_C0(f, t);      t0 = THREAD_T0(t);      DTX += C_T_RG(c0, t0)[0] * es[0] * NV_MAG(A);      DTY += C_T_RG(c0, t0)[1] * es[1] * NV_MAG(A);      flux += (C_T_RG(c0, t0)[0] * es[0] + C_T_RG(c0, t0)[1] * es[1]) * NV_MAG(A);    }    end_f_loop(f, t)    DTX /= Area;    DTY /= Area;    flux /= Area;    H_flux[i] = (32 * flux);    fprintf(fp, "Wall %d:\t DTX=%f\t DTY=%f\t heat flux=%f\n", ID, DTX, DTY, H_flux[i]);    Message("Wall %d:\t DTX=%f\t DTY=%f\t heat flux=%f\n", ID, DTX, DTY, H_flux[i]);  }  fclose(fp);}Âit builds and compiled correctly, after running the calculation I get this error=  BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= Â RANK 0 PID 41404 RUNNING AT "xxxx"
= Â EXIT STATUS: -1 (ffffffff)ÂI think is because I'm running fluent in parallel and this code is not parallelized. I have read the udf manual but is not clear to me how to parallelized the code. Should I use PRINCIPAL_FACE_P macros of the condition #if RP_NODE, RP_HOST?ÂÂAny advice is welcome. Thank you. -
September 9, 2024 at 11:11 am
Forum ModeratorAll I can do is refer you to the UDF manual. The error isn't necessarily due to the parallel setup, as that generally just returns an incorrect value for the sums as Fluent sees the partition boundary cells two or more times. Try on one node and see what happens.Â
