October 3, 2024 at 7:11 pm
13120029
SubscriberHey, I am currently trying to simulate a combustion chamber using ANSYS. However, while creating the model in ANSYS SpaceClaim, I encountered a problem. I am trying to create inlet holes on the surface of a cylinder. Can anyone help me with how to create these inlet holes?
Attached is a picture of what I am trying to create. The one circled in red is an example of the inlet hole I am trying to make. Thanks!
October 4, 2024 at 7:57 am
Devendra Badgujar
Forum ModeratorHello,Â
Once you sketch the circles on the curved surface, you will have to use the pull tool to create a cut and create a hole. Refer this Discovery SpaceClaim: Getting Started Tutorials - Pull Basics - Ansys Knowledge
FYI, Discovery SpaceClaim: Tutorials - Ansys Knowledge
DevendraÂ
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
4612
1515
1386
1209
