help missing file !! i lost my data
    • Maurok13
      Hi! i've working with Fluent and workbench so when i finish my case always i save the project in the file colum (Fluent), but in this time afther that it appears me 2 workbenchs windows i decided to close them, then when open again the case there is a window say
    • Keyur Kanade
      As best practice please always save project using File - Save on WB project page.
      When file is saved it also creates a folder named as file_name_files. All files are saved in this folder. You can find case file in this folder. If case file is not in this folder then it is lost. You will have to run it again.
      Regards Keyur
      How to show full resolution image
      How to use Google to search within Ansys Student Community
    • Amine Ben Hadj Ali
      For that reason we recommend to issue Auto-Saving. What you can do is to check in your temporary folder if you might find something you can start from.
  • The topic ‘help missing file !! i lost my data’ is closed to new replies.
