May 23, 2024 at 4:17 pm
d11943014
SubscriberHi, I want to find out the frequency response of the photodetector through impulse response from the step response and then perform a Fast Fourier transform (FFT). Here, I use the "vpd_3dB_bandwidth.isf" file from the "Vertical photodetector" example.
There is an error comes: "Error: D:/Ansys/NFET/nanosheet script/vpd_3dB_bandwidth.lsf line 16: NS_nuderiv is not a valid function or variable name"
Can you please help me to solve that problem?
May 23, 2024 at 5:41 pm
Amrita Pati
Ansys EmployeeHi Avishek,
Thanks for sharing the article details. I had a look at the vpd_3dB_bandwidth.lsf script file. Line 16 has the name "vpd_nuderiv;" This is a function which is already present in the same directory and we are calling it from vpd_3dB_bandwidth.lsf script. But the function name in Line 16 in your screenshot has a different name, as a result you see this error. I will recommend changing the name to the original name.
Amrita
- The topic ‘Help me to solve this error “NS_nuderiv is not a valid function”.’ is closed to new replies.
5824
