Help in setting up material property using APDL
    • adib.aktab999
      r/ANSYS - Help in setting up material property using APDL
      You can see the choroid body is consisted to multiple bodies. I am trying to add NeoHookean property at choroid using APDL, I have previously denoted it as porous elastic using the engineering Data and now I try to apply NeoHookean using APDL script. When I add the script for one object it is not giving any error but when I used the APDL script for all the objects it shows error, "*** ERROR ***                           CP =       1.938   TIME= 12:21:40
       TB,HYPE,,,NEO has already been defined.  Please delete existing table
       to overwrite."
      My code is:
      /prep7
      tb,hyper,1,,,NEO
      tbdata,1,1000,0.03
    • adib.aktab999
      When I have used the NeoHookean from Engineering data it gives error,
      """"*** ERROR ***                           CP =       8.312   TIME= 14:15:49
       More than one material option has been defined for material 13.
       Hyperelastic material (TB,HYPER) is not supported with other nonlinear
       material models.
       *** ERROR ***                           CP =       8.422   TIME= 14:15:49
       More than one material option has been defined for material 14.
       material models.
       More than one material option has been defined for material 15.
       material models.
       More than one material option has been defined for material 16.
       material models.
       More than one material option has been defined for material 17.
       material models.
       More than one material option has been defined for material 18.
       material models.
       More than one material option has been defined for material 19.
       material models.
       More than one material option has been defined for material 20.
       material models.
       More than one material option has been defined for material 21.
       material models.
       More than one material option has been defined for material 22.
       material models.
       More than one material option has been defined for material 23.
       material models.
       More than one material option has been defined for material 24.
       material models.
       More than one material option has been defined for material 25.
       material models.
       More than one material option has been defined for material 26.
       material models.
       More than one material option has been defined for material 27.
       material models.
       More than one material option has been defined for material 28.
       material models.
       More than one material option has been defined for material 29.
       material models.
       More than one material option has been defined for material 30.
       material models.
       More than one material option has been defined for material 31.
       material models.
       More than one material option has been defined for material 32.
       material models.
       More than one material option has been defined for material 33.
       material models.
       *** ERROR ***                           CP =       8.438   TIME= 14:15:49
       More than one material option has been defined for material 34.
       material models.
       More than one material option has been defined for material 35.
       material models.
       *** WARNING ***                         CP =       8.797   TIME= 14:15:49
       Material number 176 (used by element 207148) should normally have at
       least one MP or one TB type command associated with it.  Output of
       energy by material may not be available."""""""""
      Open the Ansys Help page for APDL command reference and look at the the TB command.
      TBLabMATIDNTEMPNPTSTBOPT--FuncName
      The command you used keeps pointing to MATID = 1 but each solid in your model has its own MATID so only the first one works and all the others are overwriting that table which is what the error says. Try using MATID in place of 1 in your commands.  That will cause the command to use the individual MATID of each solid since the command is placed under the solid being defined. That is the reason for the error in your original post.
      Note that when you use numbers in Commands that are only understood if you know what units are in use, they are interpreted using the currently set units, so if you have the wrong the units selected in Mechanical, you will get the wrong results.  Here is a link for more inforrmation about command snippets:
      https://www.padtinc.com/wp-content/uploads/2022/03/PADT_Webinar_Code_Snippets_2011_05_26.pdf
      The simplest solution is to delete all the command objects, define a Neohookean Material in Engineering Data and assign that material to each solid.  That is what you attempted for the second post, but now the error clearly states that Hyperelastic material (TB,HYPER) is not supported with other nonlinear material models, so you can't have both Porous Elasticity and Hyperelastic material models in the same material defintion. Note that Porous Elasticity requires you mesh with CPT215 elements, but your model has been meshed with SOLID187 elements.
    • adib.aktab999
      How do I mesh with CPT215 material?
Viewing 4 reply threads
