September 14, 2019 at 9:14 am
KeWu
SubscriberHi there,
I got an error of "invalid geometry" before running the simulation.
Could you give me some instructions about it?
Please see the attached.
Thanks in advance,
Ke Wu
September 14, 2019 at 1:43 pm
peteroznewman
SubscriberIn ANSYS 2019 R2, if you right click on the message of invalid geometry, the pop-up menu says Go to object.
You can see that the four Deformation Probes under the Solution branch have lost the Geometry Selection. Reselect the geometry and it will solve.
September 14, 2019 at 3:22 pm
KeWu
SubscriberProblem solved!
Thank you so much!!
Ke
July 7, 2023 at 4:50 pm
Mohammad Talha Sajid
SubscriberHi KeWu,
I couldn't find the deformation probes. Also I am using shell element in my geometry doe the solver being Steady State Thermal-Electric Analysis. Could that be the reason?
- The topic ‘Help for solving “invalid geometry”’ is closed to new replies.
Ansys Innovation Space
971
858
851
792
