TAGGED: ansys-fluent, ansys-student, designmodeler, fluent, mesh-generation
December 9, 2020 at 10:49 am
Nico
SubscriberHi all, nwhen I try to use the analysis system fluid flow (fluent), during the mesh update, I have this error:nUpdate failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent).n(DP 0) Unable to initialize addins in Meshing. Either the application crashed or Workbench lost communication with it (Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:50939).nIt doesen't matter if I create geometry with design modeler or spaceclaim or I import it.nAny suggestions on a solution to my problem?n -
December 10, 2020 at 5:43 pm
ANSYS_MMadore
Forum ModeratorArrayCan you open a Windows command prompt and run dxdiag and send the full output of the dxdiag tool? Please also run the command set and return that full output.nnThanksnMattn -
December 11, 2020 at 9:10 pm
December 14, 2020 at 1:02 pm
ANSYS_MMadore
Forum ModeratorArrayYou are missing the first section of the command line output. Can you share the output that showed above the CommonProgramFiles (x86) entry? Also, the graphics card you have is not a supported device. You can try updating your Nvidia driver (please go to Nvidia website, do not use Windows Device Manager) Then, make sure that your machine uses the Nvidia card as default. Right click on the desktop then launch Nvidia Control Panel >> Manage 3D settings >> set Preferred graphics processor to be High-performance NVIDIA processor.n -
December 14, 2020 at 3:18 pm
Nico
This is the first part. I use ansys with a second user account (with administrator rights) because my first one has ò this letter in the name so I can't even open the program with this account. Can my problem with the meshing be connected to this fact?nThank you so much again.n
December 23, 2020 at 2:37 pm
ANSYS_MMadore
Forum ModeratorAre you able to open Meshing, or does this error result in you being unable to even open the Meshing cell? Perhaps this post will have some relevance?n/forum/discussion/15378/error-unable-to-initialize-addins-in-meshingn -
January 4, 2021 at 10:29 am
January 4, 2021 at 2:40 pm
Forum ModeratorIn Meshing can you go to File-Export and write out a .msh file? Pay attention to any messages that appear in Meshing as they tend to be more diagnostic than those in Workbench. n
Viewing 7 reply threads
- The topic ‘HELP- error in ansys 2020 r2 – Update failed for the Mesh component in Fluid Flow (Fluent).’ is closed to new replies.
1535
1386
1225
