March 19, 2020 at 9:58 pm
RDelaCourt
SubscriberHi all, I hace a part my friend has 3D scanned and has sent me the image in the form of an STL file. I want to be able to modify the component. but currently it is imported as a mesh type (obviously).Â
I've tried following some tutorials online but I am having some trouble working with the geometry I currently have.
Is anyone able to shed some light on this and point me in the right direction?
I have attatched the STL file (Gearbox mount).
Any help is greatly appreciated
Thank you
Ryan.
March 20, 2020 at 2:31 am
peteroznewman
SubscriberWhat version of ANSYS are you using?
Student or other type of license?
What units are the data in the STL file? Inches, mm?
The way to use this file is as a template to create real solids from scratch while using the STL facets to help size the features.
Here is the facet body...Create a Plane then use the Tools > Extract Curves tool to get this...
 You can sketch over those rough shapes to make surfaces that can be pulled into solids and then worked on from another angle.
March 20, 2020 at 6:29 am
Keyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.Â
please checkÂ
https://www.youtube.com/watch?v=1ZnaSZEihG8
https://www.youtube.com/watch?v=sk55qdEj_T4
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Help converting STL file into solid model’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
4177
1487
1363
1194
