April 19, 2024 at 10:25 am
bowen
SubscriberHelp card
I use fluent 2024r1 bidirectional coupling with rocky2024R1, When i run a Fluidized bed case provided by the tutorial workshops. when I select the 2-way coupling in rocky and import .cas file created by fluent to Rocky. The Rocky will check the validation of that file. And it failed and showed a fluent license issue. I do not know the reason. If you have encountered and solved the problem, I hope you can receive the solution, thank you very much.The case: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/dem_tut/dem_tut_14.html.
error in the figure:
the fluent.log file:
Opening input/output transcript to file "C:\Users\B368B~1.WAN\AppData\Local\Temp\tmpipyxydi6fluent\\fluent-20240419-114311-17024.trn".
Auto-Transcript Start Time: 11:43:11, 19 Apr 2024 W. Europe Daylight TimeWelcome to ANSYS Fluent 2024 R1
Copyright 1987-2024 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.Build Time: Nov 22 2023 10:31:01 EST Build Id: 10184
Connected License Server List:Unexpected license problem; exiting.
Fluent launch args:
['C:\\Program Files\\ANSYS Inc\\v241\\fluent/ntbin/win64/fluent.exe', '-r24.1.0', '3ddp', '-i', 'C:\\Users\\B368B~1.WAN\\AppData\\Local\\Temp\\tmpipyxydi6fluent\\validate_mesh.jou', '-hidden', '-wait', '-g']fluent-999999-error.log:
Error [node 999999] [time 4/19/24 11:43:30] Abnormal Exit!
April 23, 2024 at 2:42 pm
Jackson Gomes
Ansys EmployeeHi Bowen Wang,
It seems like the issue you're encountering is related to a Fluent license problem, as indicated by the error message in the log files. Here are a few steps you can take to troubleshoot and potentially resolve this issue:
Check Fluent License Configuration: Make sure that your Fluent license is properly configured and valid.
Restart License Server: If you're using a network license server, try restarting the license server to ensure that it's running properly and accessible by Fluent.
For more information about Rocky CFD coupling, please refer to Rocky CFD Coupling Technical Manual (ansys.com).
July 4, 2024 at 8:44 am
adedejitaiwo74
SubscriberI am also having same problem. please how can I solve this problem?
August 5, 2024 at 11:45 am
Jackson Gomes
Ansys EmployeeHi Taiwo Adedeji,
Have you verified in your fluent log file if your error also has to do with the license?
If so, try to check if the fluent license is correctly configured.
Best regards.
- The topic ‘Help card!FLUENT-ROCKY 2 way coupling errors for THE VERSION OF 2024R1’ is closed to new replies.
6109
