March 23, 2022 at 3:20 am
lixiaobo
SubscriberMarch 24, 2022 at 10:08 pmGWANG
Ansys EmployeeHi lixiaobo
Thank you for the post. Could you please elaborate a bit on what you mean by "The bottom line of the eye diagram is flipped upwards"? We see a higher noise level on the level one signal than the level 0 signal which is reasonable given the thermal and short noises on higher power signal are also higher.
March 27, 2022 at 7:34 amlixiaobo
SubscriberThanks, I mean I can't see an eye shape in my simulation image, is it because I set the intensity too high and the noise is too high? Do I have to set the intensity to a very small value to get a normal eye diagram? If I have to turn the intensity up, what parameters do I need to modify to get a good eye diagram?
March 28, 2022 at 10:43 pmGuilin Sun
Ansys EmployeePlease do not duplicate posts in different language forums.
Viewing 3 reply threads- The topic ‘Hello, may I ask why the eye diagram I simulated with the interconnect is this shape? I didn’t find’ is closed to new replies.
