3D Design
3D Design
Hello, I have a question, how to copy 2D lines, etc. to create another 2D design?
    • Georgiro
      Hello, I know that here in 19.2 exists the possiblity of creating another sketch of 2D objects, however I do not remember how to remember it. Can you help me to work it out? I just do not want to re-create again the same geometry, I just want to copy the parts of lines, etc.Thanks
    • Keyur Kanade
      you can use following.
      select plane - right mouse button - insert - sketch instance.
    • Georgiro
      This is absolutely perfect, but still I am not able to select plane (do you mean to select  e. g. XYPlane or quite absolutely different one?), right button does not make anything that I could use of the result and of course I am not able to find Insert and Sketch instance. Unfortunately. So if you can quickly tell me how to find it? Thanks a lot.
      You'll need two planes and then you should be able to copy the sketch from one plane to the other.
      https://www.eureka.im/2401.html
      If you have surface bodies you can also use Pattern or Move which may be easier.
    • Georgiro
      OK, now I understand it, it is perfect and it works pretty well. Thanks
      Jiri
    • Keyur Kanade
      good that you got it.
      if this helps you, please mark this post as 'is solution' to help others on forum.
Viewing 5 reply threads
  • The topic ‘Hello, I have a question, how to copy 2D lines, etc. to create another 2D design?’ is closed to new replies.
