October 18, 2021 at 12:12 pm
gopal1608
SubscriberI AM UNABLE TO START ANSYS MECHANICAL ,THE WORK BENCH AND DESIGN MODELER WORKS FINE, BUT WHENEVER I START ANSYS MECHANICAL I GET THIS MESSAGE , "the application has crashed or has lost communication".
CURRENTLY I AM USING ANSYS 2021 R1.
PLEASE SUGGEST ME A SOLUTION I HAVE BEEN FRUSTRATED BECAUSE OF IT AND UNABLE TO LEARN ANSYS MECHANICAL.
October 18, 2021 at 12:12 pmgopal1608
SubscriberPLZ SUGGEST ME SOLUTION
October 18, 2021 at 2:06 pmRob
Forum ModeratorCan you run through one of the tutorials? Just trying to check if the error is specific to your model. Please post inline images of the errors.
October 19, 2021 at 3:43 pmOctober 19, 2021 at 3:59 pmRob
Forum ModeratorCan you save the project and re-try? If that fails also post the full path where the files are stored.
October 21, 2021 at 3:27 amOctober 21, 2021 at 4:09 pmRob
Forum ModeratorPlease provide the full path. Are there any "odd" characters in the path, userID or machine name? By odd, I mean £ $ or non-English letters.
October 22, 2021 at 12:43 pmgopal1608
SubscriberNO THERE ARE NO ODD CHARACTERS THERE IN THE PATH .
CAN YOU PLEASE PROVIDE ME A LINK, TO DOWNLOAD THE PREVIOUS VERSON OF THE SOFTWARE ,LIIKE 18 OR 18.2 BECAUSE I'M REALLY FRUSTATED WITH THIS PROBLEM NOW ,I'VE TRIED ALL THE POSSIBLE WAY OUT THERE .
October 22, 2021 at 1:09 pmGeorge Karnos
Ansys EmployeeOctober 26, 2021 at 6:28 amOctober 26, 2021 at 1:34 pmGeorge Karnos
Ansys Employeewhat is the output from:
ping -4 localhost
ping 127.0.0.1
hostname
ping ###### (Where ###### is the returned info from the above command-hostname)
October 26, 2021 at 1:55 pmOctober 26, 2021 at 2:00 pmGeorge Karnos
Ansys EmployeeWhat is returned from:
ping gopal-PC
What Operating System are you using?
October 26, 2021 at 2:04 pmOctober 26, 2021 at 2:16 pmGeorge Karnos
Ansys EmployeeUnfortunately, Windows 7 is not supported.
The downloadable versions require a minimum of Windows 10.
Please see the System and Browser Requirements.
https://www.ansys.com/academic/students/ansys-student
October 28, 2021 at 3:48 amgopal1608
SubscriberBUT I AM ABLE TO OPEN ANSYS WORKBENCH,AND DESIGN MODELLER THINK ONLY ANSYS MECHANICAL NEEDS WINDOWS 10 IF THIS IS THE SOLUTION, THEN I WILL NEED TO UPGRADE MY WINDOWS THANKS FOR THE SUPPORT ,CHEERS TO THE ANSYS TEAM :):):)
Viewing 15 reply threads- The topic ‘hello’ is closed to new replies.
5694
1891
1419
