August 29, 2021 at 1:18 pm
219bm1006
SubscriberI am designing an helical antenna for a wavelength and as helical antenna is a slow wave structure it will have a phase velocity and depending on that we will have a frequency. So, there are two frequencies depending upon light velocity and phase velocity. Am I right in this conception? If right, How to simulate this, I mean, what are the parameters that are need to be changed in the project manager section?
August 30, 2021 at 5:29 amAndyJP
Subscriberthere are always different phase and group velocities in dispersive structures, and most non-uniform boundary structures are dispersive.
draw an equation line, then extrude a cross-section along, or just apply a thickness. for faster simulation use polygonal line without curved surfaces.
do not use polygonal approximation in eigenmode, when defining a small part of the spiral. because the partial section start and end may not fit if not cuvelinear. and they should fit tightly for producing correct eigenmodes (dispersion curve). That is a kind of topological phase effect which will always make cross-sections not fitting if approximating the spiral with uniform polygons.
P.S. the "light line" is the TEM wave dispersion cone in vacuum. The velocity which you are calling a "light velocity" is a phase velocity. And since it is a simple ratio of phase number, yes, it is linked to the resonance. But strictly speaking, the phase number(or wavelength) defines the resonance. Beware that in nonreciprocal media, the sum of both-way phase numbers defines the resonance. HFSS driven modal is capable of solving nonreciprocal media (i.e.broken time reversal, where broken spatial reversal is your spiral twist)
August 31, 2021 at 4:20 pmPraneeth
You can use Antenna toolkit which comes along with the AEDT installation by which you can synthesize the antenna for any frequency.
You can also follow the standard literature available to go through the design equations governing the antenna design.
All the very best.
Viewing 2 reply threads- The topic ‘Helical antenna design for a particular wavelength’ is closed to new replies.
5824
