October 20, 2023 at 5:13 pm
DUICG
SubscriberHi, I am researching a multi-phase porous non-equilibrium thermal model. It is a multilayer model. I have two adjacent zones (fluid) and two UDS defined for each zone. The UDS are to calculate the solid temperature of their respective zone. The wall interface between the two zones is shared (shadow/coupled). Do I need to define the conduction heat transfer between the two UDS?
October 24, 2023 at 4:00 pm
Forum ModeratorIf you want to pass information from one UDS to another, or through a wall you'll need to code that.Â
- The topic ‘heat transfer between two user defined scalars’ is closed to new replies.
