October 9, 2023 at 6:36 am
menastap
SubscriberHello everyoneÂ
I am trying to simulate heat trasnfer between multiple domains shown as following. The domains from top are solid, liquid, solid, liquid, and liquid.
The model used was k-e realizibleÂ
The inlet for bottom fluid domain was pressure inlet of 5MPa
The inlet for fluid above bottom domain was pressure inlet of 6MPaThe inlet for fluid at the top domain was pressure inlet of 6MPa.
The fluid specified for the top two domains was kerosene and ideal gas air for the bottom oneÂ
October 9, 2023 at 8:50 am
Forum ModeratorOK, what's the problem?Â
October 9, 2023 at 9:48 am
October 9, 2023 at 10:13 am
Forum ModeratorOK, part of the problem is you have different fluids touching - ie there's a cell zone with air in it. Should that be kerosine? Otherwise find the interior that bounds the two zones (7 & 8) and make it into a wall.Â
See how that behaves.Â
- The topic ‘Heat transfer between multiple domains’ is closed to new replies.
5674
1890
1419
