May 2, 2024 at 3:12 am
May 2, 2024 at 4:14 pm
Guilin Sun
Ansys Employee -
May 2, 2024 at 4:18 pm
Victoria Zhang
SubscriberThanks for your reply.
I build a new simulation by myself. But it had another error "
Refinement limit exceeded for optical generation rate constraint. The mesh is valid but may not be adequately refined."
Could you give some comments on this error?
Thanks.
May 2, 2024 at 5:02 pm
Guilin Sun
Ansys EmployeeThis error is normal: it means that the generation rate is high and needs finer mesh. However the mesh iteration has reached its max number. You may try to reduce the injection power with smaller scaling when importing the generation rate for an inital test. Once it works you may consider increasing the MAX REFINE STEPS or adjusting the SENSITIVITY setting to allow for more refinement where needed. This can help ensure that the mesh is adequately refined to capture the necessary detail in the electrical quantities' variation, especially in areas with significant changes in the optical generation rate. https://optics.ansys.com/hc/en-us/articles/360034918633-CHARGE-solver-Simulation-object
Please note that the forum policy is one post for one topic. If the problem changes please write a new post. Thank you!
- The topic ‘heat simulation’ is closed to new replies.
5694
1891
1419
