March 18, 2022 at 5:33 pm
RBJ
SubscriberHello,
I have a model of a tunnel. When running in transient, heat loss is being modeled through the walls. When switching the run to steady-state (the only difference), suddenly no heat is being lost through the walls. Is this a quick fix? Am I missing something simple or is more information needed on the model?
Thanks
March 21, 2022 at 11:54 amRob
Forum ModeratorIf the transient model worked, but steady didn't check the temperature field. Steady is the equilibrium result so if there's no heat being added via a boundary/cell condition you won't see any heat transfer.
Viewing 1 reply thread- The topic ‘Heat loss not being modeled when switching from transient to steady state’ is closed to new replies.
3572
1188
1076
1063
952
