Heat generation due to Friction – Rotation BC Setup
    • kkolha2
      I want to run a simulation, which shows the Heat Generation due to Friction in between the two discs.
      As shown in the Picture, the grey plate is stationary (Fixed on the bottom side) & the Light blue disc should move in a circular motion(Shown by the red arrow) along the top surface of the grey plate.
      I am running the Analysis in Coupled Field Transient, where I need to output the Temperature plot occuring on the surface of the grey disc due to friction.
      I tried to add a remote displacement to the face/edge of the blue disc, but it seems to rotate about its own axis.
      How should i proceed with setting up the boundary conditions that will replicate the setup?
      Thanks for your help!
    • Ashish Khemka
      Can you try chnging the origin of the coordinate for remote displacement to the center of the gray disc?
      Ashish Khemka
    • kkolha2
      Hi Ashish,
      Thanks for your reply.
      Yes, in the initial solve, I used the Global co-ordinate system with origin (0,0,0) which is at the center of the grey disc.
      Please advise.
      Best,
      Kanishka
  • The topic ‘Heat generation due to Friction – Rotation BC Setup’ is closed to new replies.
