Heat flux through given paths do not match the heat flux reaction probe
    • pgl
      Why does heat flux through given paths not match the heat flux reaction probe?
    • Arun Kumar
      The total heat flux probe gives the heat flux at a given surface irrespective of direction and this may be the reason why the results differ. To check the result in a better way evaluate the heat flux results in specific direction (X, Y or Z) at a given surface
  • The topic ‘Heat flux through given paths do not match the heat flux reaction probe’ is closed to new replies.
