February 8, 2020 at 8:36 am
Koruth
Subscriber We have a aluminium casing through which there are 4 channels that carry a coolant.The properties of the coolant used ie transformer oil have been entered at the inlet of the inlet conditions. The interior of the casing is maintained at 390 C and there is a constant heat flux of 23000W/m2. The inlet is set as a pressure inlet and the inlet temperature are 2 bar and 5 C. We aren't able to specify any convective property at the solid liquid interface.As a result of which there isn't a temperature rise at the outlet.The heat given to the inner surface of the casing is not translated to the coolant passing through the channel of the casing.
Can i get any information on to why there isn't a rise in temperature at the outlet end of the channel.
Thanks in advanceÂ
Regards
koruth
February 10, 2020 at 3:56 pm
Forum ModeratorYou should have a wall-wall:shadow pair between fluid & solid with coupled wall type. If you don't the fluid & solid parts may not know about the other.Â
February 12, 2020 at 5:42 am
Koruth
SubscriberThe wall-wall shadow is with coupled wall type option.But still we aren't able to establish the relation between the fluid and the solid zones. Can we know what are the possible means to enable the fluid to carry the heat. The contours obtained from the analysis doesn't seem to justify a proper cooling for the casing.The image shown below is for the fluid channel.
February 12, 2020 at 6:25 am
DrAmine
Ansys EmployeeCheck first of all under Flux Reports and Total Heat Transfer Rate if fluxes are exchanged over the connection wall. A better description of the case including pics of geometry and named selection could also helpful for us to assist.
February 12, 2020 at 3:21 pm
February 12, 2020 at 4:45 pm
Forum ModeratorHow many volumes do you think you have and need? Flow in a pipe would usually need two zones, the fluid and the solid. I can see 5 in that image.Â
February 13, 2020 at 5:59 am
Koruth
SubscriberThe solid zone is the part001 in the assembly and the part002 are the coolant channels that pass through the casing.
Thank you
RegardÂ
KoruthÂ
February 13, 2020 at 4:03 pm
Forum ModeratorIf you have wall & wall:shadow what contact regions are you talking about?
February 14, 2020 at 11:45 am
Koruth
SubscriberAnsys created 4 contact regions between the fluid and the solid while opening fluent. We weren't able to specify any boundary conditions to these regions.
Thank you
regardsÂ
koruth
February 14, 2020 at 11:51 am
DrAmine
Ansys EmployeeWhich boundary is assigned then? INterface?
- The topic ‘heat carried by the coolant’ is closed to new replies.
