November 3, 2023 at 3:28 pm
utkarsh.patel
SubscriberHello,
Does Ansys Have material properties available of an HDPE Foam that has 4lbs per cubic feet density. I am running some analysis and I need further material properties to solve material related errors I am seeing. Currently I only have density added under added material.
November 7, 2023 at 10:26 am
Aniket Chavan
Forum ModeratorHi Utkarsh, Material properties are input, and should be coming from actual material testing data. Sample material data we provide, is sample and is for reference, only.
-Aniket
November 7, 2023 at 12:03 pm
utkarsh.patel
SubscriberHi Aniket, Sounds good. Thank you.Â
- The topic ‘HDPE Foam Material Properties’ is closed to new replies.
1307
