LS Dyna
LS Dyna
HC and TC in thermal analysis in a material
    • javat33489
      Hi all.
       I use these units:
      When adding the THERMAL_ISOTROPIC card, you must enter the parameters HC and TC.
      In what units should I do this, taking into account my units?
      I have the following data:
      For degrees I will use Celsius. And in what units will I use HC in TC?
    • javat33489
      It seems I figured out the data based on mm and kg:
      But I still get the error
    • ashish.khemka
      It looks that you found a solution.
      Ashish Khemka
      • javat33489
        No, I have an error and the solution stops:
      • javat33489
        Tell me which cards should I show you? I would like to solve this error.
      • javat33489
        Help please
    • ashish.khemka
      Please wait for the members to comment.
      Ashish Khemka
      • javat33489
        I really need your help. Tell me which cards to show, I’ll make screenshots. I'm desperate.
    • armin.abedini
      Hi Javat,
      I have a question regarding your model: Does this error occur due to the *MAT_THERMAL_ISOTROPIC card that is used to define material thermal properties? It might be relevant to other cards utilized for the thermal-structural simulation.
      • javat33489
        I use cards:
        INITIAL_TEMPERATURE_SET
        CONTROL_THERMAL_TIMESTEP
        CONTROL_THERMAL_SOLVER
        CONTROL_SOLUTION = 2
        ___
        ___
        Whatever parameters I use in MAT_THERMAL_ISOTROPIC there is always an error. I'll try to turn off these cards and run the calculation. Then I will turn them off sequentially to understand where the error is. Thanks for the advice. I'll write what the result is.
      • javat33489
        Hello.
        I tried different options but the error still appears.
        I did some tests. I'll tell you more.
        I'm using calculation time 7.5.
        The drill material is plastic kinematic, the material is SPG sand MOHR_COULUMB.
        I wrote above which units I use.
        I manage to make the first entry in d3plot, but at the next step an error occurs.
        I changed the timestep parameters of the temperature solver and the HC and TC parameters in the MAT_THERMAL_ISOTROPIC settings (for drill and sand).
        1.
        With these settings, the sand temperature is noticeably very high:
        2.
        With these settings there are generally negative temperatures
        ___
        Where to go next? What to watch or configure? Please tell me?
Viewing 4 reply threads
  • The topic ‘HC and TC in thermal analysis in a material’ is closed to new replies.
