March 11, 2020 at 11:22 am
RamonFHerrera
SubscriberHaving the Student Edition and the Commercial Edition concurrently in the same PC. Is this doable? Advised? Best practice?
-Ramon F. Herrera
JFK Numbers
ramon@jfknumbers.org
March 11, 2020 at 1:34 pm
Forum ModeratorGiven the Student version is to learn on, and not for commercial use why would you have both versions? Definitely not advised, both from a licence terms and practicality point of view: the licence managers don't play well.Â
How did you get on contacting us re the software?Â
March 11, 2020 at 1:52 pm
RamonFHerrera
SubscriberThanks for your kind assistance. With your reply my suspicions are confirmed. In my job I do a lot of software testing and have several concurrent version. With the Autodesk applications this is not a problem.
I have a unique problem to solve, it is detailed here:
At this point, I am trying to decide whether my project can be processed by the Student Edition or needs more "horsepower".
Google is your friend (and mine). The support in ANSYS other forums is a disgrace. This is the only one where I get replies.
Thanks again,
-Ramon F. Herrera
JFK Numbers
March 11, 2020 at 3:09 pm
Forum ModeratorIf you're doing a research project you may want to review the Academic licencing: we distinguish between commercial & research. I also need to point out that Student is for learning, not for PhD project work: read the licence agreement you clicked (probably without reading!).Â
Similarly, Student & Commercial/Academic aren't different versions: they're different licences. I have about 6 versions of Fluent and 4 full Ansys installs.Â
As an aside, which Ansys forum are you referring to? You've just got 2 threads on here that I can see.Â
March 11, 2020 at 3:21 pm
RamonFHerrera
To these:
ANSYS Forum
Plus one in Reddit, Engineering Forums, etc.
I tried several and only here I got a reply (thanks!)
Yes, I am aware that those forums are not owned by your employer.
-Ramon
JFK Numbers
ps: What I am doing is personal research. I have a 1-person Not-for-Profit entity. I intend to perform Cranial Ballistics simulations in order to determine the details of the fatal shot to president Kennedy on November 22, 1963. This needs a high resolution cranium model but the free student edition that I have is limited in the number of "cells".
- The topic ‘Having the Student Edition and the Commercial Edition concurrently?’ is closed to new replies.
