January 10, 2019 at 2:26 pmOimpaSubscriber
I have a question about prograssive damage in frp.
in Damage Initiation Criteria i use Hashin criteria for all 4 failure modes.
Can I use MPDG method for damage evolution when i use Hashin criteria for Damage Initiation?
January 10, 2019 at 2:49 pmjj77Subscriber
I would imagine so. Hashin is a failure criteria, while is MPDG is damage evolution, which is degrading the material, once damage initiation (failure, e.g., according to Hashin) has occurred (e.g., reducing stiffness of elements ones damaged). So they go hand in hand.
January 10, 2019 at 3:05 pm
January 10, 2019 at 3:45 pmjj77Subscriber
As mentioned I would imagine that it works since it does not say like for CDM that Hashin is the only criteria that can be used, it says 1,..19 so it says that it includes all failure criteria. Give it a try and see how the material degrades once damaged, and look at the damage progression.
If you are looking into the apdl commands for Hashin failure this paper describes it well. Hope it helps
Copy paste link into your browser:Â
barbero.cadec-online.com/papers/2017/AnsysPDABarberoShahbazi_website.pdf
January 11, 2019 at 7:11 amOimpaSubscriber
Thank you very much for your help
January 11, 2019 at 9:25 amjj77Subscriber
No worries. Glad I could be of help. Please if this has answered your question mark it as closed. Many thanks. jj77
- The topic ‘Hashin failure criteria’ is closed to new replies.
421
198
178
162
142
