December 26, 2020 at 7:56 am
DIWAS
SubscriberHello, I am new to ansys fluent, let alone multiphase flow is difficult. I am trying to consider air and snow as a multiphase flow(mixture model), I want to define every condition but I have limited knowledge in ANSYS fluent as well as the User Defined Functions. I got few helps from guides and youtube but right now reaching nowhere. If anyone can help me to accurately simulate the snowdrift accumulation. It would be very helpful. Thankyou.n -
December 28, 2020 at 11:07 am
Forum Moderatorin answer to the question, yes we have. Snow drifts and sand dunes. nRead the notes on eulerian multiphase, and have a very careful look on how you'd apply that. n -
January 11, 2021 at 9:21 am
DIWAS
Subscriberthank you for the reply... My professor wants me to use mixture model, is it possible? I have read about the multiphase flow, Mixture, VOF as well as Eulerian Multiphase. I know the common difference. Should I consider steady or unsteady state simulation?n -
January 11, 2021 at 9:50 am
Forum ModeratorMixture will work, and that's how the snow drifts were done by the Swedes in the early 00s. There was an article published in Fluent News (it's pre-Ansys work) but I don't have a copy and it's unlikely to be on the Ansys website because of it's age. nYou may want to look up some of the work by Bagnold from the 1930s & 40s on sand movement: it's much the same phenomena, just warmer. n -
January 11, 2021 at 10:31 am
Amine Ben Hadj Ali
Ansys EmployeeMixture Model can be used with the default slip velocity or an adjusted one modeling snow fall speed. Alternative is to use DPM. n -
January 15, 2021 at 9:52 am
Vineet
Subscriberhello mate!! I am also trying to solve almost same problem. It would be better if we could have some discussion on the topic.nnThanks in advance.n -
January 15, 2021 at 10:58 am
Forum Moderatorif you start by posting where you've got to then everyone can comment. n -
March 22, 2021 at 12:36 pm
DIWAS
Subscriberthank you for the reply... I got a little help from my supervisor... I applied a udf code and did a steady simulation. Now, I want to try dynamic mesh for erosion and deposition.n-
July 28, 2023 at 8:03 pm
kiran.purushothamakeshavan
SubscriberHi, I'm working on a similar problem, the accumulation of snow on surfaces. It would be great if you could throw some light on the general outline of how you proceeded to generate meaningful results
March 22, 2021 at 2:04 pm
Amine Ben Hadj Ali
Ansys EmployeeGreat!n -
March 22, 2021 at 4:17 pm
Forum ModeratorExcellent. Remember with moving mesh you can't add or remove surfaces (ie add or remove topology) so you will need to be a bit careful with the initial set up. n
Viewing 9 reply threads
- The topic ‘Has anyone done simulation of snow fall or drift in ANSYS fluent?’ is closed to new replies.
- affinity not set
1487
1318
1157
