Harmonic vs Transient Dynamics
    • afshintaghvaeipour
      Dear Experts,
      I have a clamped beam, first, I try to conduct a modal analysis to extract natural frequencies. Then, around the first natural frequency, I conducted a Harmonic analysis, with a force at the end tip. I got the response spectrum of the end tip displacement. Now, I am trying to conduct a transient dynamic analysis while a simple harmonic force with the same amplitude as the the harmonic and a frequency close to the natural frequncy is applied at the end tip. I expect to get the steady displacement amplitude same as a value on the response spetrum corresponding to the applied frequency. However, they are diffrenet. Would you answer why it happens. Noteworthy to mention that I defined similar damping on both analyses.
      Thanks
    • erik.kostson
      Hi
      Should be the same (same frequency force and amplitude – so at resonance  – aslo both need same damping) – use though MSUP transient and MSUP harmonic for best comparison.
      MSUP Transient:
      https://www.youtube.com/watch?v=3fHu5fMHNeU
      MSUP Harmonic:
      https://www.youtube.com/watch?v=_1BASk_VyCQ
      If you do that they are the same (displacement at the same location say at the tip).
      All the best
      Erik
  • The topic ‘Harmonic vs Transient Dynamics’ is closed to new replies.
