May 17, 2023 at 8:10 am
Samuele Luigetti
Subscriberhello everybody
i'm doing harmonic response of a structure. I set a constant structural damping coefficient, but appears the message "the system is solved without damping", and i do not understand why since there is damping in effect.
May 17, 2023 at 8:33 am
ErKo
Ansys EmployeeHi
As long as you can see the effect of damping in the results (reduced peaks around resonance) and that it is different compared to without damping, that is the most important (the warning message can then be neglected).
All the best
Erik
May 17, 2023 at 9:22 am
Samuele Luigetti
Subscriberok thanks but why it appears?
May 19, 2023 at 1:43 pm
peteroznewman
SubscriberWas the Harmonic Response a stand alone analysis or was there an upstream Modal analysis Solution cell linked to the setup cell of the Harmonic Response creating a MSUP Harmonic Response analysis?
Do you have any elements such as springs or bushings in the model that included damping?
May 19, 2023 at 2:42 pm
Samuele Luigetti
SubscriberHi peter, it's MSUP analysis, not stand-alone. I have springs, but without damping, only with stiffness.
May 19, 2023 at 3:47 pm
peteroznewman
SubscriberWhat version of Ansys are you running?
In Ansys 2019, Structural Damping was not supported for MSUP Harmonic Response.
In Ansys 2022, Structural Damping is supported for MSUP Harmonic Response.
May 20, 2023 at 1:03 pm
Samuele Luigetti
Subscriber2022 r1
May 22, 2023 at 4:54 pm
peteroznewman
SubscriberSo in 2019 in a MSUP Harmonic Response, there was some code to warn you that if Constant Structural Damping was the only damping then the warning message was "system is solved without damping".
Then in 2022, they support Constant Structural Damping. Is it possible that they forgot to delete the code that issues the warning message? Maybe.
I like Erik's suggestion, solve once with 0.0 Structural Damping and solve again with a 0.1 Structural Damping and see if the magnitude of the peak response is reduced.
May 22, 2023 at 6:30 pm
Samuele Luigetti
Subscriberyes i tried two different coefficient and the response is different, so the damping is on
- The topic ‘harmonic response-damping’ is closed to new replies.
6745
1324
1067
