Process Integration and Design Optimization
Harmonic Frequency respons into signal processing
    • 202108277
      I want to input the frequency respons function into the signalprocessing block, so i can calculate its error from a known result. After that i want to do parameter optimization to fit the simulation to the meassured data. How can i make a variable in the signal processing blok with the FRF, so that it updates with all the new simulations when done with optislang sensitivity and optimization?
      Hope my request makes sense, I will much appreciate any help you can offer.
      Best regards
      Lynge
    • Markus
      Hi Lynge,
      form my understanding you need to export the response to a text file.
      For inspiration, this has been done in the Spring Steel Example you find here: Examples
      How to read in a File in Signal Processing is shown here:
      Calibration of a Damped Oscillator in Ansys Workbench
      I hope this helps you.
      Best regards,
      Markus
