Harmonic Forced Response
    • Tayyip
      Hi everyone,
      I calculated many aerodynamic damping coefficient values as a function of the inter-blade phase angle (IBPA) in CFX. Next step, I will enter the calculated minimum damping coefficient as "constant damping ratio" in harmonic response analysis. Is this method true for harmonic forced response analysis?
    • Sandeep Medikonda
      Tayyip,
        Moving your question to the appropriate forum so that you can faster help.
      Sandeep
    • Tayyip
      Hi Sandeep,
      Thank you for your advice. I've moved it.
      Have a good day,
      Tayyip
  • The topic ‘Harmonic Forced Response’ is closed to new replies.
