harmonic-based optimization
    • Md_Salem
      I am carrying out optimization process using Ansys 2022R1 workbench for geometric configuration under harmonic load.
      My concern is to apply the harmonic load at the frequency of the first mode shape ( first natural frequency) which can be obtained from pre-modal analysis as a value.
      I wonder if i can make the Ansys repeat the modal analysis after optimization is done (for the new geometric configuration)  and ahence extract the new first natural frequency , then repeat the optimization with the new load frequency and so on ?
      In other words, can I implement the harmonic analysis to go under first natural frequency (or any aother selected natural frequency) directly from the modal analysis ?
      Regards
    • Chandra Sekaran
      Within the Mechanical GUI the frequency value at which to carry out the harmonic analysis has to be typed in. There is not a way to use the first natural frequency from a modal analysis. However you can potentially do this using APDL command snippets. I am thinking you can do the following:
      1. in the modal analysis in Post1 *GET the first natural frequency. Write this to a file (*CFOPEN, *VWRITE, *CFCLOSE) to a known folder, say, d:\test
      2. In the harmonic analysis read this frequency from the file (*VREAD) and use HROPT to apply the frequency range with NSUB,1.
    • Md_Salem
      I think it is pretty good trick, I will try it and let you know
      I just wonder if it is possible to achieve the process shown in the attached flowchart ?
    • Md_Salem
      Hello Chandra,
      I did the first part of the solution (get the 1st frequency and write it as a parameter to *.txt file)
      Now I have a problem with workbench harmonic analysis, which is how to force the solver to bypass the  (analysis setting) of workbench solver and read the analysis setting from my APDL macro code ?
      *VREAD,Fd,MODES_F,TXT,E:\  !(Fd parameter for frequency & MODES_F.txt is the file)
      (F12.4)             !(fortran format)
      HROPT,FULL
      HROUT,ON
      LUMPM,0
      EQSLV, ,0,
      PSTRES,0
      HARFRQ,0,Fd,
      NSUBST,1,
      The workbench keeps telling me (invalid "Range Maximum") even if I put numerical value directly instead of Fd.
      I think that the problem is in the (Analysis Setting) table which has to be filled up with values or deleted or doing a bypass to enforce workbench solver to take the analysis setting form the APDL macro
      Regards
  • The topic ‘harmonic-based optimization’ is closed to new replies.
