September 18, 2020 at 6:42 am
andreapirocca
SubscriberHello,nnI see that both in the Harmonic Acoustic and Harmonic Response modules in Workbench a thermal condition load is not supported. Is there a way to implement it with an APDL script, in order to obtain the frequency response of a structure with an oscillating thermal load applied?.Thank you,nAndrean -
September 21, 2020 at 10:34 am
Ashish Khemka
Forum ModeratornnYou can insert in a command object with following commands:nn/solu (before solving in the Setup)nantyp,harmnharf,1nnsub,1nnsel,s,loc,x,0nd,all,temp,100 ! load will vary +/-100 nnsel,allnoutres,nsol,1nsavensolvenfininn/post1 (for post-processing)nset,lastnplns,tempnnRegards,nAshish Khemka -
July 17, 2023 at 2:14 pm
a.lagreca
SubscriberHi All,
I've the same problem but I didn't catch your tips...I've to apply different thermal loads on different parts of my FE model before running an harmonic analysis. In Ansys Mechanical I know what to do but in AW I don't yet.
Waiting for your kind feedback.
Antonio
- The topic ‘Harmonic analysis with a thermal load’ is closed to new replies.
1510
1386
1209
