TAGGED: analysis-setting, apdl, frequency, harmonic, workbench
November 14, 2022 at 5:19 pm
Md_Salem
SubscriberHi everyone,
Isn't any way to force the workbench to read the harmonic analysis setting from APDL macro instead of proceeding from "analysis setting" table ?
i.e I need to make the harmonic analysis to deal with the input frequency range as a variable that can be read from external file by using APDL macro in workbench
November 16, 2022 at 6:39 pm
wrbulat
Ansys EmployeeHi,
I just did a test to investigate. A cantilever beam is subjected to a constant 1 m/s^2 base acceleration. In Analysis Settings, I specified that the sweep is over frequency interval [0 Hz < f < 250 Hz] divided into 50 frequency intervals:
I used a command object to override these settings [100 Hz < f < 250 Hz] divided into 25 frequency intervals):
This is a mode superposition harmonic response analysis (not FULL). The command object appears to have taken precedence (which is, as I understand it, want you want to accomplish):
Kind regards,
Bill
November 18, 2022 at 8:34 pm
Md_Salem
SubscriberÂ
Hi Bill,
I am speachless, if this procedure suceed with me , it will be such victory
I will try it and let you know for the good of others ?
November 20, 2022 at 7:51 am
Md_Salem
SubscriberHi Bill,
I have tried this method , it worked pretty good. final remark to be in consideration , the written APDL macro harmonic analysis frequency interval should be within the frequency interval of analysis setting given by workbench , otherwise it will not work properly
i.e you have to use -large- frequency inerval in the analysis setting to insure that the given APDL frequency interval lay in side it.
Best of Regards
- The topic ‘Harmonic analysis setting’ is closed to new replies.
4868
1587
1386
1242
