October 12, 2020 at 8:36 pm
JHPontes
SubscriberHi all,nI am working on a rotordynamics project, and would llike to perform a harmonic analysis.nI've seen a discussion about inserting APDL commands to include rotordynamics effects such as coriolis and gyroscopic matrices. However I feel a little confused about the SYNCHRO command. As far as I understand when using the SYNCHRO command the analysis should be performed with the excitation on the force equal to the frequency of shaft rotation (used on the gyroscopic matrix calculation), so the result obtained would be a frequency response plot.nDoes that means that if I perform the same analysis without the SYNCHRO command and specifying a rotational velocity by OMEGA or COMEGA command (not quite sure what is the difference) I would obtain an unbalance response?nThanks a lotn -
October 15, 2020 at 4:10 pm
Aniket
Forum ModeratorJHPontes, Please check the help links:nSynchro command specifies whether the excitation frequency is synchronous or asynchronous with the rotational velocity of a structure.nOMEGA Specifies the rotational velocity of the structure.nnCOMEGA specifies the rotational velocity of an element component about a user-defined rotational axis.nand finally, for Rotordynamics analysis, please check:nandn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumnn
- The topic ‘Harmonic Analysis rotordynamics’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1467
