July 3, 2023 at 1:59 pm
Pedro Argote
SubscriberI am performing an harmonic analysis, I can obtain the logical results and I would like to ask you a basic doubt in order to clarify the obtained result interpretation. In a full method harmonic analysis, when I introduce a discrete excitation, I mean an excitation of 0,5 mm as amplitude at a specified frequency, for example at 9 Hz (considering that the amplitude value is 0 for the rest of frequencies). If the first natural frequency of my structure appears at 15 Hz, should I ontain any stress or displacement results at the frequency of 9 Hz?
I know that at that frequency I will not have any amplification and the stress or displacement results should keep low. I thought I would obtain any result different to zero, but I did not gat them. So, my question is that if the frequency of my excitation is far from the natural frequencies of the structure, should I get results in a Full Method or in a Modal Superposition Harmonic Analysis?
Thank you very much for your help!
July 5, 2023 at 1:49 pm
dlooman
Ansys EmployeeBoth full and mode-sup harmonic should give non-zero results at 9 hz. At very low frequencies the result will approach a static solution, but will not be zero.
July 5, 2023 at 3:06 pm
Ruturaj Gavali
Ansys EmployeeHey Pedro!
Please see if the Ansys videos below are helpful:
Performing Mode Superposition Harmonic Analysis
Performing Harmonic Analysis with Full Method
Correctly Interpreting Harmonic Results
Thanks!
For more information, check out the following links:
- The topic ‘Harmonic Analysis Results’ is closed to new replies.
5934
1306
