Harmonic Acoustics – Problems while setting Thermo-Viscous BLI Boundary
    • André Henrique
      I just can't set Thermo-Viscous BLI Boundary for the surfaces I want.
      The model is as follows, a tube filled with air and a structure inside. I want to place a Thermo-Viscos BLI Boundary condition on the surfaces where the solid interacts with the fluid.
    • ErKo
      Hi
      It can not be applied on a fluid solid interface (FSI), so on  a face where the structure interacts with the acoustic region.
      The BLI goes only on outer faces of acoustic regions (not in contact with any structural bodies) – see as an example here: 41.5. Boundary Conditions and Loading (ansys.com) –
      See here if you can not open the above link:
      All the best
      Erik
  • The topic ‘Harmonic Acoustics – Problems while setting Thermo-Viscous BLI Boundary’ is closed to new replies.
