June 3, 2024 at 4:40 pm
castrohenrique0208
SubscriberHello everyone.Â
I want to perform an modal simulation to extract the modes using only the panel, then the acoustic cavity and then the system panel+ acoustic cavity.
After, I want to perform an harmonic analysis to extract the sound pressure level generated in the system panel + acoustic cavity.
My main goal is to extract the sound level pressure, but I'm a little bit ansure about the process.Â
I try using the harmonic acoustic, but i'm get 2 error messages.Â
1 - The program controlled far-field radiation surface detection option chosen in the analysis settings could not find any surface that are a part of absorption element/surface, impedance/radiation boundaries or artificially matched layers interface. The post processor will not be able to evaluate far field results.Â
2 - An error occurred inside the POST PROCESSING module.Â
If someone would like to see the project, i would send it. Â
June 3, 2024 at 4:49 pm
ErKo
Ansys EmployeeÂ
Remove the far field result– take that away and it works.
Like it says:
So since you do not have any of those (absoprtion, radiation bc,..) it can not do that (far field calcs.) – what you have is a plate inside a room with rigid/hard walls – that is the natural bc in acoustics when no bc are defined on a face so can not look on far field outside a room with rigid walls :).
All the best
Erik
June 4, 2024 at 10:52 am
castrohenrique0208
SubscriberHello Erik.Â
My problem is that when I try to apply any boundary (radiation/absorption), I get this error ?, when I select the corresponding body.ÂÂCan you explain how I can measure the SPL in different locations?Â
July 14, 2024 at 7:51 am
stbenca
SubscriberÂ
- The topic ‘Harmonic acoustic analysis’ is closed to new replies.
5909
1306
