3D Design
3D Design
Hardware limits for Discovery Simulation
    • dinhan0394
      Dear all,
      I have a question regarding hardware limits for Discovery Simulation.
      Are there any hardware (GPU) limitations when using Discovery Explore mode?
      I only found information about the number of CPUs when using Refine mode, other than that there is no information related to Explore mode
      That means, as long as I have a Discovery Simulation license, I can use the maximum GPU I have without any limitations, right?
      Thank you,
    • Atharv Joshi
      Hi Dinhan,
      There's no as such limitation you should be able to use your maximum GPU.
      Here's the article on hardware requirement that you can refer to Ansys Discovery Hardware Requirements (2024 R1) - Ansys Knowledge
      You need a minimum 4GB of dedicated NVIDIA GPU, Maxwell series or newer with updated graphics card driver.
      Let me know if you have further questions.
      Thanks and Regards
      Atharv
      • dinhan0394
        Thank you very much for your answer. I understand
  • The topic ‘Hardware limits for Discovery Simulation’ is closed to new replies.
