August 30, 2024 at 2:10 pm
Yacoby Woo
SubscriberIf two closely contacted cylinders of different materials to be penerated from outerside are created with the lagrange solver here, the modeling can not operate correctly since the gap does not meet the requirement. Using the "Convert IJK Parts to Unstructured" under the import command may solve the problem. I am wondering whether I should select all the three options available and what is the difference if not so.
(the sketch of the contacted cylinders to be penetrated)
(the three available options)Â
August 30, 2024 at 4:09 pm
ErKo
Ansys EmployeeDuplicate. In the future refrain from creating multiple posts.
As mentioned in the other post use the LS-Dyna/Explicit dynamics forum (this forum is for APDL and mech. implicit solvers):
https://innovationspace.ansys.com/forum/forums/forum/discuss-simulation/ls-dyna/
Closing here
- The topic ‘Handling contact in Autodyn’ is closed to new replies.
5649
1885
1404
1303
