October 11, 2024 at 1:24 pm
ChengYuxuan
Subscriber为了得到一个具有侧壁角的圆弧,我使用官网给出的语法案例进行修改,但遇到了如下问题:
1.使用语法来创建polygon的圆环,据我的理解在0°时他们是齐平的,但在这里出现了陡峭峰,且给出的点数不是我设定的1000*2,而是少了很多,请问是为什么呢?
newproject;
# octagon properties
n_sides=1000;
r1=300.5e-6;
r2=299.5e-6;
# x,y position of each corner
theta=linspace(0,30,n_sides);
theta=theta(1:n_sides);
x1=r1*cos(theta*pi/180);
y1=r1*sin(theta*pi/180);
x2=r2*cos(theta*pi/180);
y2=r2*sin(theta*pi/180);
# combine x,y into one vertices matrix
V1=matrix(n_sides,2);
V1(1:n_sides,1)=x1(1:n_sides);
V1(1:n_sides,2)=y1(1:n_sides);
V2=matrix(n_sides,2);
V2(1:n_sides,1)=x2(1:n_sides);
V2(1:n_sides,2)=y2(1:n_sides);
V3 = polydiff(V1,V2);
# add polygon object and set the vertices
addpoly;
set("vertices",V3);
set("name","polygon_extruded");
set("z span",2e-6);
V3=get("vertices");
?size(V3);
2.使用如下语法设置侧壁角,得不到有效结果;但将上述代码换位简单的矩形代码(无MatrixDiff),可以得到侧壁角结果,请问是为什么呢
poly_old_name = "polygon_extruded";
poly_new_name = "polygon_sidewall";
poly_vertices =get("vertices") ;
addlayerbuilder;
set({"name": poly_new_name, "x": 5e-6});
set("gds sidewall angle position reference", "Bottom");
set("geometry", {"1:0": {poly_vertices}});
addlayer;
setlayer("default name", "name", "poly_layer");
setlayer("poly_layer", "layer number", "1:0");
setlayer("poly_layer", "thickness", getnamed(poly_old_name, "z span"));
setlayer("poly_layer", "pattern material", str2num(getnamed(poly_old_name, "index")));
setlayer("poly_layer", "sidewall angle", 75);
谢谢回复!
October 11, 2024 at 11:47 pm
Guilin Sun
Ansys Employee-
October 12, 2024 at 4:54 am
ChengYuxuan
Subscriber是设置另一个结果与该结果重叠,另一个结构的mesh的overlap优先级更高吗?
October 13, 2024 at 1:40 pm
ChengYuxuan
Subscriber验证了一下这种方法也不能生成侧壁角,应该怎么修改呢
October 12, 2024 at 4:53 am
ChengYuxuan
Subscriber请问overlap应该怎么设置呢?
October 14, 2024 at 5:20 pm
Guilin Sun
Ansys Employee关于结构重叠,请参见
Ansys Insight: Lumerical 不用布尔运算如何设置嵌套结构 (mesh order)
至于带壁角的环形,有人用Bézier,还有人用结构组中的 N-sided polygon toroid 一层一层实现。
5719
