Grey/White Spots on Contour CFD Post
    • JorgeP
      Hello dear friends,nnSo after I ran my simulation, I used CFD post to see the results. I want to see the results 200m (and others) above zmin. So I created an user surface, transposed 200m from wall and the used the contour to see. But when the results are displayed, some white/grey marks are appearing as is possible to see on the attached image. I've tried on different computers and the same is happening.nn What can I do to solve this? I read that AMD graphics cards may have influence on it, but tried on a computer with Nvidia and got the same. Thank you!n
    • subhamdas
      Try the following:nDisable the user surface and increase the number of contour lines(only the contour should be enabled). However, this would have a slight effect on the quality of contour, since I had also observed the same behaviour earliernInstead of user surface, create a plane and plot the desired variable on the plane. This would yield a much better quality of contourn
    • JorgeP
      It worked ! i don't see significant differences in the quality of the contour though.nThat unfortunately is not an option, because I do need to have the surface contour for better undestanding and explanation.nnThank you for your help ! n
    • subhamdas
      That is what a plane does, you can simply define the plane as offset from surface, and you would get a plane similar to the user surface that you have created. Also that would yield a surface contour of better quality.n
  • The topic ‘Grey/White Spots on Contour CFD Post’ is closed to new replies.
