July 16, 2021 at 3:46 pm
Jayda
SubscriberHi Forum,
I've used an UDF for gray band absorption coefficient: DEFINE_GRAY_BAND_ABS_COEFF(gray_band_scat, c, t, nb).
Now I also want to define a UDF for gray band scattering coefficient. However, I do not see a definition for a gray band scattering function in the manual? I've tried DEFINE_GRAY_BAND_SCA_COEFF() but that does not work. I cannot load a UDF DEFINE_GRAY_BAND_ABS_COEFF() function into the scattering coefficient in the FLUENT materials panel neither.
Would you maybe know a solution? Thank you!
Jayda
July 21, 2021 at 5:20 pmSurya Deb
Ansys EmployeeHello,
Can you check DEFINE_PROPERTY to specify the scattering coefficient?
Check the link for more information on DEFINE_PROPERTY. [https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/flu_udf/flu_udf_sec_define_property.html]
Regards SD
July 22, 2021 at 8:38 amJayda
SubscriberHi SD Yes, I did. But I want the scattering coefficient to be identified per band, as I do with the absorption coefficient (via DEFINE_GRAY_BAND_ABS_COEFF). I know how to define a UDF of the class DEFINE_PROPERTY. The issue is that via DEFINE_PROPERTY there cannot be a scattering coefficient that is different in different light wavelight bands.
Why is this not possible for the scattering coefficient? And is there a way around? Thanks!
Kind regards
Jayda
December 22, 2021 at 11:30 amJA_95
SubscriberHi Jayda I am trying as well to solve this problem, did you find how to do it?
Thank you very much and kind regards JA
Viewing 3 reply threads- The topic ‘Gray band scattering coefficient’ is closed to new replies.
5739
